I have desktop PC running under XP and USB IrDA adapter. PC suite won`t recognize my N9210 unless I disable vitrual IC port via device manager and enable it. Only then it finds the phone. I start PC suite and begin to sync but in the middle of the process it stops and it shows message "Disconnected"? Any idea?
PC Suite 9210, Win XP and Irda connection problem?
same problem here.. but it doesn't connect at all :-?
There is new version (2.0 something) of PC suite which don`t seam to have problem with recognition but it still stops sync after while...
An1?
I haven gotten to the point where the phone is recognised, I can syncronise the calender, but not contacts or backup..... had any further luck?
Red Devil
