Worms on 3650
63 replies · 11,920 views · Started 27 June 2003
I have WORMS (not Snails) but i have little memory.
I boot phone in SAFE mode, i have about 2.5 MB of free ram.
Start JAVA-WORMS its ok. i have menu, i click to start game-ok but when i can play then about 5sec. game crashes !!!
Admins/Mods can monitor PM activity.So if you request and exchange warez via PM might result with a Warning or Ban!
I got this one too, but you can play like 10-30 seconds after it says 'Memory full', so it's kinda useless...
I got about 2.8MB of RAM free.
Edit: Worms running background, i got ~100KB-250KB of RAM free...
[quote="jimmy-floyd"]OK,i thought about it,although i cant help you ivomir,coz i havent got WORMS,..pity.. :cry:[/quote]
Oh really?! Anyway,i think that this is the correct location: http://kiloo.com/
Do you have sLauncher installed?
Turn your phone off - plug in charger - press and hold menu key - menu will come up and you can select the game - but look at your RAM, stacks more because the 'telephone' application is not running!!
Will.
No. I don't have SmartLauncher...
So, SmartLauncher let's you use phone without running it or what do you mean by this?
[quote="Guest"]Turn your phone off - plug in charger - press and hold menu key - menu will come up and you can select the game - but look at your RAM, stacks more because the 'telephone' application is not running!! [/quote]
When you hold the menu key while powering on,the phone skips the boot procedure and the phone app is not started,hence more RAM.
but its a silly question,but i cant find link to download worms :P 😮ops: 😃 ,here is its page http://kiloo.com/kiloo/kiloo.nsf/pages/3F643409D05EE8B488256CD2006D1C2A?OpenDocument ,but no link.
With sLauncher installed and following those instructions you can turn your phone OFF and still access the menu system to run applications.
This will give you LOADS MORE RAM because the 'Telephone' application is not running.
Look how much ran I have...
Helps me for playing DOOM or running OPERA
[quote="Anonymous"]With sLauncher installed and following those instructions you can turn your phone OFF and still access the menu system to run applications.
😊[/quote]
This is not possible.
Nokia 7650 have 4MB of ram
Nokia 3650 have 3.2 MB of ram
so how do you have 4,41 of RAM ?????????
are you using some RAM packer?
All that is running is sLauncher?
Does that 'make' more ram, i don't know, but you can see i have no special programs running.
I don't know about 3650 only having 3.5 mb of ram, perhaps they mean after the 'phone' application is loaded, I can only tell you what I see.
And it works and I can run program that previously complained about no memory..
IVOMIR
You still have 'telephone' running.
Follow my instructions to start your phone and bypassing the loading of 'telephone'
Follow my instructions - it works!
Turn your phone OFF
Plug in charger and let it start charging
Press and hold the menu key and wait for sLauncher to fire up
(it will, even thou the phone is OFF!!)
Voila
Press menu key once again to access your programs and away you go
IT WORKS!!!
Have you sounds in the games?
I have in some, but in some doestn and some app. or games is very slow 😞
Press 'menu' once again and sLauncher shows you your applications in the normal way...
Sound works fine on Worms.
Guest: i noticed that after i posted...
Edit: now Worms is running fine.
I never use sound in doom or Opera so it's never been a problem for me?.
Sorry - Guest is WILLBRADY - I'm on another desktop and cant remember my login 😊
No I can not find the download either Jimmy 😉
I'll do a google see what it throws up.
Try load into sLanucher very small skin. Then you have many free mem. But i have still no sound in Worms.
But DOOM WORKS WITH SOUND RULEZZZ !!!!!!
I just installed SmartLauncher so i got normal skin that comes with it. Anyway to get that original S60 skin for SmartLauncher?
