Camera and Vibration API's for the P800
5 replies · 1,692 views · Started 28 June 2003
I don't know if this had been posted before. Just an information for those who want to know about the new API. Read about it and download the applications if you want, here
Old, it may be old, but are there any applications that uses it at all? Its been so long.. :-?
This could be a VERY old news. But looking at the downloadable application, one of them is only dated June 11, 2003 so I thought it could be a good information for people who would like to try it. That's what a forum is for, isn't it?
The Sony Ericsson Camera API implementation of the Symbian Onboard Camera API Design described in SGL.GT0126.031) is implemented for the P800 smartphone and compatible with P800 Organiser software CXC162001 R2A14 and later. The Camera API supports still image capturing of RGB bitmap based pictures of three sizes and direct-to-screen view finding of one fixed size (QQVGA). All mandatory methods are supported, but optional features of the Symbian Onboard Camera API Design such as video, flash and zoom are not supported.
Mine is still CXC162001 R1C02. I wish I have the latest so that I can have a go and tell you more.
dont worry max all news is good news on the p800 i did not know about this app so thanks 😃
keep it up max
API stands for Application Programming Interface and baiscaly its bunch of features that programers can use in their apps.So its not an app,and its not of any use to non developers.
