"app. closed sdDAEMON user exec-3"msg.
4 replies · 3,411 views · Started 28 June 2003
What is the meaning of ths alert msg and h0w to deal with it,pls help...
Try searching for this in the forum before posting as it has come up before....It would also help if you were a bit more descriptive, i.e. when this normally happens..
i can tell you that it is space doubler at fault, you can solve it by unpacking the app thats causing the problem.
Tnx,but how cn i remove sdoubler?Coz its n0t in my app. Manager?Is it n0rmal that sdoubler is n0t in my app. Manager but it is currently installed?Tnx
