TechHELPXFILES!
1 replies · 812 views · Started 29 June 2003
Good day y'all!May i knw wot is "PSINT eLIB (C) PSILOC",i tried 2 remove it in my applicationsMANAGER but it says if i do that it wil stop d running of some apps.Wot d (to..ot) is dat?!Some kind souls help me pls!And 2 some,dnt give me d shit dat i have 2 search a thread 4 it had been discussed b4,my answer 2 ya,TRY BROWSING AAS thru WAP and tell me about it dummy!Peace out....
Its a bunch of libs,dll files that apps you have bought from psiloc (www.psiloc.com) depend on.So,don't delete it unless you plan not to use any psiloc software.
