Hi!
Despite my best attempts, the Nokia PC Suite for 3650 (Firmware 3.13 dated April, 2003) cannot get integrated with Bluetooth USB Dongle from Widcomm. But I am able to transfer data to phone from PC using right click option. So Itried to transfer a wav file through BT. But when I tried to play it, I got a message saying that the format is not supported. Similarly, a small mpeg video also is too big to fit in phone memory as by default a BT message goes first to Phone Memory. Can anyone please suggest a way of converting wav and mpeg in to appropriate formats (without Nokia 3650 PC Suite) so that I can play the same on my phone.
Playback of wav files and mpeg movies without PC Suite
you can change your message settings so that your messages go directly to your MMC. go to menu, messages,option, settings, others (the last option in the menu) and change "phone memory" to "memory card".
there's a software from nokia that converts all kinds of media to the ones supported by the n3650's integrated software. It's called "multimedia converter" and it can be found here. the best option is to let pc suite do the conversion. widcomm works fine for me... I'm using FW v2.50...
