How to send logos/Pictures/Ringtones with 3650/7650.
Is there any program to send these files?
Thanks.
Thanks.
[quote="Anonymous"]How to send logos/Pictures/Ringtones with 3650/7650.
Thanks.[/quote]
Hello there!
Try downloading FEexplorer. It is a free program and you can send files from your phone either by bluetooth, infrared or even via text message.
Hi
Maybe I'm doing something wrong but when i send a ringtone (MID) using FEexplorer to a 3510, which reads MID files ... I can either send it as a text message, which it isn't attached to in any form ... Or when I try to send it using MMS it says incorrect format on my phone ...
Any helpers on this ???
Picked this thread up from almost a month ago, so it does prove that I search ... 😉 ... hehehe
Cheers
BSK 😃
Its not easy to send midi files from phone.
1. Get the zip program from www.wildpalm.co.uk
2. Zip the mid file
3. Send it
4. wont neccessarily work as the networks have blocked most files from MMS
Thanks JyriK ...
I've read on other forums that it is impossible to send MID files ... & zipping it up, wouldn't deliver it in a format that is suitable for a nokia 3510 ...
So I will keep on searching to find another way ...
Thanks for the info though ...
BSK 😃
