skinz
1 replies · 1,340 views · Started 30 June 2003
where to fined the small icons for skin editor ,anybody have any idea i like to change some icons in the skins,
i have a great 3650 with:
SSaver,Sdouble,Systemtool,smart luncher,skin editor,total IR,cameraFX,hip cam,cam timer,ETI camcorder,efileman,Switsher,torch,pcounter,handy day,handy reminder,worldclockpro,ringtonestudio,cocktail,hunter,MGS(carting,jewel impulse,pool,siverball,steelwarrior,APP(FIFA2003,Magic elements,pang)
Try making your own ones as they are very easy to do using even a very basic photo manuipulation package.
Basically you need the icon, make this 1.1cm X 1.1cm (this is the size I've found works well) save this as say "contacts". Then what I do is save it again, adding Contacts_Mask. Now change this one so that any colour other than the white background is black. You should end up with an exact replica in shape and size as the main icon, but just in solid black.
You can use any pictures you like within reason, some work better than others I have found.
Try it out, you'll soon get the hang of it.
To get you started search for icons on the net and modify what you find/like to use on the phone.
Ian
