detect memory leak
3 replies · 3,133 views · Started 01 July 2003
hi
How We can detect the Memory leaks in Symbian?can any body suggest a solution to implement it ???
thanx in advance,
Saurabh
If you suspect that memory is leaking then guard this part of your code with UHEAP macros:
__UHEAP_MARK
DoSomething();
__UHEAP_MARKEND
When something is left on the heap in DoSomething() the code panics.
hi moak,
it works fine...thanx for this...
i have found it on:
http://www.newlc.com/article.php3?id_article=90
regards,
saurabh
