Which 7650/3650 programs do you use most often?
0 replies · 3,468 views · Started 01 July 2003
This questionnare is only about built-in 7650/3650 programs, not 3rd party.
- which programs do you use most often?
- can you access most frequently used programs easily in Menu?
- have you moved programs to folders or from folders to main level?
- have you changed the order of programs in Menu?
- how long did it take before you found out that you can move programs to folders?
- which programs shouldn't be in the main level but in a folder in Menu?
