File Explorer Expired!
12 replies · 3,262 views · Started 01 July 2003
I went to use my FExplorer on my phone today, and it came up with a message saying, "This betaversion hais expired" Does anybody know where i can get the full version? Is it free?
[quote="jimmy-floyd"]hm,as i know FE(the new one.)is for free,..HEY DOMI,do you what is it,bug or is it trial[/quote]
Umm, it's obviously a BETA with time expiry :roll:
Get the latest (for free) from www.gosymbian.com
So if you have downloaded FE from link that GHOSTDOG gave,and it expiried,there is something wrong..OR JUST download FE from link ,that GhostDog gave.
GhostDog has not even posted in this thread :-?
And what do you mean cracked version? FXplorer is free! Arni must have an old beta version of FXplorer installed, if he updates it at www.gosymbian.com it will be working fine again (hopefully!).
Cheers
Good old Jimmy.
Arni, if you stick around these forums you'll get used to Jimmy.
He's like an annoying itch you can't reach to scratch 😉
Will 😊
I had the same problem with FXplorer. I believe there was a time limited version of 1.10 released slightly before the proper version of 1.10.
Simply go to www.gosymbian.com and download the latest release, all problems solved 😊
Hi to all,
When I have worked a little bit ( :P ) on new functions, I regularly update a download link with the version in beta test , but the beta always expired (to avoid having multiple non final versions on the way), you have probably downloaded a beta version, please, in this case, re-download the final (first, un-install the beta to be sure), final version never expired.
all final (and beta) can be downloaded thru www.gosymbian.com (download section)
Hope it's clear .... 😉
Enjoy this version,
Domi.
