How to count total number of contacts inside contact list?
5 replies · 2,598 views · Started 02 July 2003
Anyone know how to count total number of contact list? Are there any appl to help counting how many contacts i have added?
There is an application that gives you this information but for the life of me I can not remember what its called... will post when I remember.
ANd jus for the info, can be picked up at
http://my-symbian.com/uiq/applications/applications.php?faq=39&fldAuto=194
Anyone tried ? Comments ?
tried it - works perfectly to solve Edgedale's problem. also very good if you want to delete a load of contacts at once.
I can't say it is the sort of app you would use very often, but if you don't sync to a pc then it is the easiest way of deleting your contacts.
also has a compression facility....
