RMR Task (For Editing)
1 replies · 12 views · Started 02 July 2003
Seems like a good review to me 😊
I've just corrected a couple of bits of punctuation.
and just a couple of suggestions.
At the end of the 1st sentence perhaps change
"but its worth in business circles is undiminished"
to
"but it proves its worth in business circles."
And if found the following a bit unclear
"While RMR Task lists all your Tasks on the one page, it has not one category, but two! You can rename these to whatever you like (I use Project and Type of Work, but you could just as easily have "Application" and "Member of Staff" or "website" and "Type of Change"😉 as the two indicators as to what is needed on each Task."
Perhaps change it to the following if this is what you meant?
"While RMR Task lists all your Tasks on the one page. It has not one category, but two and you can rename these to whatever you like. I use "Project" and "Type of Work", but you could just as easily have "Application" and "Member of Staff" or "Website" and "Type of Change" as the two indicators as to what is needed on each Task."
