screensaver one hour behind... again...
4 replies · 1,988 views · Started 02 July 2003
Hi all!! I think I've read all the threads concerning this subject that exist here in AAS, but unfortunately none of them gave me an answer to the problem. I'm trying psiloc's screensaver and both the big clock as well as the small one (in "show indicators"😉 appear one hour behind. This doesn't happen everytime, but after a couple of times using it, they go back one hour... Is there a solution to this? =((((
mine just did the same thing
did you ever find out why
mine is a tril verson and it said i only had 6 days left. not sure if that has anything to do with it
mine did the same, but i re-installed it and uninstalled Total Remote and it works fine now. i'm not sure if total remote has anything to do with the problem, but i just i'd tell you the steps i took that seemed to fix the problem.
uninstalled and reainstalled a couple of times.... between a pair of them I even formatted the phone... strange... I really like the small clock on the bottom of the screen...
Mine shows the correct time until i log in to gprs. then it's messed up. have to restart the phone to fix it. might be something with the time setting on the server it connects to.
