Hi all, does anyone know how i could put my aol account onto my 7650? Does anyone know the incoming/outcoming mail server?
Aol mail box help
its not possible to use aol mail using smtp or pop,
you neeed to go to http://mobile.aol.co.uk/redesign/onyourphone/index.jsp
you wont be able to send atchments or recieve them though but you can use the aol messenger .
otherwise go to www.freeserve.com
register for the no ties package . register then set up freeseve on your mobile. . you can access your mail via gprs or standard wap. anyproblems mail me at [email protected] and ill give you all the settings etc
hope this helps
