Storage of surplus DUO Memory Sticks
12 replies · 2,789 views · Started 03 July 2003
By now most of us will probably be in possession of two or more MSD's, most likely a 16MB, a 64MB and a 128MB. The question is then where to store the surplus cards: you'll still want to take them along for those extra MB's ?
You have probably noticed that under the cover, at the top end of the battery, there is amble space to store two cards:
Off with the cover, in with the cards, on with the cover again, and off we go.
However, when re-opening the lid you don't know exactly where the cards will be, and if you are juggled just at the moment you re-open the cover, then the cards will be all over the floor.
Two solutions to this: both of them work well. One is a little complex, involving slight modifications of the battery.
The other is very simple...
Edgedale - credit where credit is due... a genius at work... I am going to follow your lead, thanks mate :P
Great Job! Where did you get the clips from? Would clipping the clip on the battery, bulge the side of the battery making it hard to put on the case? 😊
Wow Cool!!! 😃 Just wonder if it has any side effect for the memory stick? Memory stick on the battery?
Don't think so. It's a customise clip. Perhaps you can ask hardware store guys to customise for you.
