Anyone know of a way I can send a .sis files to my n3650 over the web.
Some sort of MMS service maybe?
Preferably a free one?
Ideas would be nice, forum browsing does not really answer it.
Also, the nokiasoftware market currently has some v.cool stuff for the 3650. Recommended.
as i know,you can send some files via MMS to your e-mail.,and then via N3650 browser .e.t.c. operao,and then download these files to your N3650.
What you do is, you put the file or app you want on your screen, locate whoever you want to send it to, and then throw your 3650 as hard as you can in that direction. Hopefully you aren't a total fag, and your throw actually reaches the other person. But if they don't catch it well, or if your throw is weak, buy another 3650 and try again. Take care now.
[quote="Genius"]What you do is, you put the file or app you want on your screen, locate whoever you want to send it to, and then throw your 3650 as hard as you can in that direction. Hopefully you aren't a total fag, and your throw actually reaches the other person. But if they don't catch it well, or if your throw is weak, buy another 3650 and try again. Take care now.[/quote]
Yes.. thankyou mr.buttholesurfer.
:agrue:
Thanks for some helpful info. others.
Figured someone might have setup an over the web file service for MMS phones.
If you have access to any webspace you can put it up there and then just go there with your browser like jimmy says.
Or setup your e-mail account on your phone and download the fle to your PC and e-mail it to yourself.
If you see the file on a webpage whilst surfing on your PC, quite often if you type that url directly into your phones browser you will be able to download that file direct to your phone too 😊
But a lot of companies .zip there files first which can be a pain.
Best 😊
Will
You have a good idea there, WillBrady(hope I typed in your name right).
You can upload files on any normal free internet site. One good example is www.TopCities.com
This website offers 150MB of free space. Even though you do not have a webpage, just upload files, type in the complete URL on your phone and you will be downloading files in no time.
8)
Just like that?
Excellent.
So I can potentially define a wap site as easily?
I get unknown file format on a .sis file.
What? Can't throw far enough!? you fucking tosser! You smoke pole don't you? :x
be quiet now.
No one cares about you...
