I confirm that the 7650 does not support audio on bluetooth devices so i can't use my bluetooth car handsfree equipment. I hope there will be an upgrade fro nokia otherwise when p800 will be avilable i'll sell my 7650 :evil:
No bluetooth audio on 7650
so does this mean i cant use bluetooth at all on the 7650 or is it just audio
will i still be able to download things to pc using b/tooth
[quote="Anonymous"]so does this mean i cant use bluetooth at all on the 7650 or is it just audio
will i still be able to download things to pc using b/tooth[/quote]
You can use Bluetooth for downloads and uploads of data to a PC. Its just audio Bluetooth that it does not support. However I think its a bad move on Nokia's part not to support it 😞. Can anyone think of a reason why they dont?
Yes, you can use bluetooth with another 7650 or with a PC (with conectivity card). I think!
From what I've read in reviews etc. you can sync. with your PC using bluetooth etc.
The problem is essentially to do with using a bluetooth handsfree kit. It is not supported. A lot of people are hoping the software will get upgraded, and it will become possible.
If you are planning on getting some bluetooth kit to allow PC Sync. make sure you get something that has been tested with the Nokia, not all PC bluetooth gear will work.
Take a look at
http://www.infosync.no/news/2002/n/2088.html
Talks about bluetooth connection in it somewhere.
Zuber
i m afraid that a 7650i is cooming soon(biger memory,audio Bluetooth 3band etc)
remember what happend with 6310 & 6310i :evil:
