Hi
just recently bought a Nokia 3650 and I have some problems with my Bluetooth transmisions
my problem is that I can't send files from my phone to my PC
but I can send files from my PC to my phone
I saw a post about the 7650 to change in the registry.. I did that.. but it didn't work
I am using a "Bluetooth USB Dongle" by Gigabyte
One other thing worth mention is that I can't open the Nokia software it says that I need to connect my phone to my computer
Please Help
Thanx
//knaalto
Good grief! the same thing is happenning to me. Sucks!
Is there anyone out there who can help us?
my bluetooth connection is a D-link DBT-120.
software: widcomm bluetooth software 1.2.2.15
Do a search guys - both here and on the 7650 forums.
You'll find LOADS of info which should get you up and running.
Sounds like you need the new widcomm drivers and then tinker in the registery.
There's loads of tips on here that will explain it much better than me - I think the main thread was in the 7650 forum.
Best
Will
Thank you Mazevedo! 😃
Problem solved.
Ppl wiv the same prob go to his thread 'Bluetooth - 7650 -> PC Problem solved in the WidComm stac' in the 7650 section! 😃
Cheers!
horned rat
