Ho to use your 3650 like WebCam [FREEWARE]
46 replies · 15,619 views · Started 04 July 2003
Works on my 3650 - very impressive.
Can this be streamed to a webpage???
In my industry I can think of MANY applications for this 😉
That may be because you are linking to it while viewing it via the google english translator?
- go back to the italian site and then it should download just fine 😊
Will
Thanks Ghostdog - got softcam & webcam32 up and running with it now, streaming over GPRS from phone to server then onto the webpage - works pretty good 😊
I'm off to our lapdancing club - anyone want the webcam url 😉
Will.
No problem will.I didn't have any luck geting it to work with my 7650,the webcam app is for the 3650 only i guess.
i love this app.easy to use,freeware....great.But dont know why i can only save 5 minutes of streamnig video on my comp?
Can't download it, a popup comes up, I think it's asking me to register/login. I dont even wanna try and do that as its all in Italian (i think) and i cant understand any of it! I dont see how you guys got it???
Could somebody send it to my email if u cant find a solution for me... (email in my profile). Thank you very much!
Arni
never mind, when to translated site, got registered then logged in on italian and downloaded it. :evil: This better be worth it...!
Ok, its very good, but is there a way i can use it on MSN Msnger? Cos i try and start a 'Webcam' conversation, but it says it cant detect a Webcam. 😞 I have Mobilewebcam open.
For some reason that site refuses to recognise my login details. Any chance someone could post the application here?
Cheers,
Ptm
Probably it can't be posted here.Well,maybe,if someone contacs the developers and gains permission from them.
No worries. I just checked my email and saw a confirmation to respond to. I got it now. 😊
ok i download it i got two files. do i sent them to my phone or install one on my computer and the other on the phone
I wish there was a program that could do this over bluetooth...
I don't have the need to enable gprs really.
EAX - It does work over bluetooth.
Just get your connection with mRouter - enter your PC's IP and away you go.
My objective is to use my 3650 on MSNM with a friend who also has a webcam. I have downloaded the necessary software (which i understood to be necessary from other forums) which are:
Softcam
WebcamXP
Remote S60
and I use a Bluetooth connection.
Could somebody explain in numbered steps on how to reach my objective?
Install 'softcam' from www.luminositi.com
Get a connection with Mobile web so you can see the stream from your phone on your desktop.
Start netmeeting or whatever comms software you have configured to use with MSN, 'softcam' will then open too - put it into 'live' mode and a window will appear on screen, whatever is 'under' that window is what gets streamed so move it on top of the streaming video from mobile web and away you go..
Best
Will
[quote="Arni"]NetMeeting isnt compatible with XP 😞
What other software can work using MSN[/quote]
NetMeeting certainly is compatible with XP! I use it frequently!
Start -> Run -> conf
Cheers
