Nokia phone turning itself off.
9 replies · 2,026 views · Started 05 July 2003
I've been using my phone as an alarm clock, but for the past few days I've woken up to find that my phone was off. I know for a fact that no one has turned off my phone.
Is this normal? It's been doing this since I first got it but wasn't as frequent as it is now. Time to send it back to Nokia for repairs?
EDIT> I have charged the battery fully on all occasions.
i have had the same problems not always with the alarm clock but somtimes i just leave it and it will turn its self off after a while even fully charged.
[quote="meerkatzukin"]I've been using my phone as an alarm clock, but for the past few days I've woken up to find that my phone was off. I know for a fact that no one has turned off my phone.
EDIT> I have charged the battery fully on all occasions.[/quote]
That is not a good sign, dude. =(
Mine was busted and it will not even turn on. Try upgrading the firmware or check if your battery is still running good.
My 3650 did the same. Turned out it was a software problem. Had to send the handset off for repair.
Pls open cover battery sim then installed back n start ph after 5 min then see.If problem wl same go to service n update ph
yea,turning of ,maybe caused by contacts of sim card,also,if yours N3650 turns of by himself,DONT worry,just see what progs you have(maybe wildskinz),or cracked,if you have such progs,delete them.
[quote="Infinityx"]My 3650 did the same. Turned out it was a software problem. Had to send the handset off for repair.[/quote]
Hey dude!
Hows your phone right now? Is it still under repair?
Some people keep saying cracked software fooks up yr phone. Well mine is RAMMED with warez. Has been for 3 months and I never had a single problem. Phone rebooting is apparently a known bug. Fortunately mine hasn't caught it yet!
