.sis file downloads
5 replies · 2,850 views · Started 05 July 2003
Ok, how can i send sis files from my PC to my 3650 without a data cable? I tried sending to topcities.Com, but it won't upload .Sis files. ???
SIS files tend to be quite large; probably better if you could transfer it somehow. Maybe VIA bluetooth or ir?
Well,sis files have different sizes,the largest one i have seen was Doom7650,1.6 MB or something,the smalles one was 6K.Usually they are 100-200K so i don't think they are big.
Infinityx,you need to find a public webspace that alowes uploading of sis files,or try seting up a e-mail account on your phone and send your self an e-mail.
It's really worth investing in a bluetooth dongle or at least infa red - if you send many files over the air youll soon spend the price of these gadgets on your data bill
will
I spent �10 on a card reader from PC World and find it the quickest and easiest way to transfer files. But you need to download a file manager to the phone 1st via bt, ir or wap.
Hmmm... Will only b downloading the occasional file, so don't want to spend a vast amount on a solution to my problem. I can view my o2 e-mail using GPRS on my handset, but can't view or open attatchments
