Does anyone know of any software that will allow me to connect my 3650 to my pc.
please help im struggling to find any !!
thnx
jayteas
thnx
jayteas
get an infrared or bluetooth adaptor for your pc. there's no datacable connection for 3650.
yes there is a data cable connection for th 3650 i have one.
I have spoken to some people and they said support is being added for data cable connections.
Are you sure?Where would you plug the data cable in?
i bought it off e-bay but ive also found a few on various web sites. some include a software disk with them. To set it up you plug the sim card and battery into the datcable. That connects to the phone and the cable makes contact with both the battery and sim inputs. The memory card stays in the phone.
If anyone does here of any software that works please let me know !!
From the above there's also a row of pins that connect through a small hole under the sim card.
[quote="jayteas"]From the above there's also a row of pins that connect through a small hole under the sim card.[/quote]
Can you post some screenshot? I haven't seen it before, and I think many of the member here also.
With USB Bluetooth adapters available for around $20, it seems more of a hassle than it is worth to use a cable that takes so much effort to utilize... :robot:
