What are the type of video files that 3650 can play?mpeg?rm?3pg?
and if possible plz give your best format that gives you the best quality while saving precious memory space 😃
Video file type playable on 3650???
Well if you are encoding your own files, the lower the bit rate the smaller the file size. But also the lower the picture quality. You pays your money, you takes your choice... 😊
From my own xperience i found the Realplayer format gives the best picture, i would go for quality over memory usage everytime.
EvIlDeViL
Real One Player can play RM or 3g.... When you send to the phone by PC SUITE the program will convert the .avi mpg mpeg mp4 nim wav mov
Only you need is to have the quicktime installed to transfer the ext. .mov for the pcsuite to convert PCSUITE
Cya
