INSTALL FIFA
8 replies · 2,604 views · Started 06 July 2003
I have just downloaded this file but it doesn't say how to install, can anyone help pse. :roll:
You probably didn't get any replies because of zero details about your problem.What file,sis,jar,txt,zip,exe?If its a jar or a sis its preety easy and you should read the manual about such basic operations.
fifa is a java game, make sure you have the file on your pc ending in .jar, then send it to your phone and then it'll install
The file I downloaded was from a decent site, it is titled[ NOKIA 7650 ] EA Fifa 2003 and is made of of various bin and wav files. I cant find a jar file but do I need to rename anything.
:angel:
Try this,zip the folder containing the game files(I think jar files use the zip algorithm)and rename it to *.jar(Replace the "*" character with some name,like fifa)and send it to your phone.That should do the trick.
Lets not start another pointless discussion,jotty asked for some help,he didn't ask for warez or post warez.
