Is there software out there to enable the 3650video-recorder to capture video+sound together? And to take clips longer than 15sec? Took some video of superbike racing this weekend, nice video, but strangely silent.
Video + voice together.
Just found an upgrade for video recorder that allows video+voice capture at the same time. My video clips are still only 15sec long though...(sigh).
hi the reason they are 15 secs long is to keep the file size under 100 kb so thay they can be sent by mms , if they were over 100kb then mms would not be able to handle it.
i think there is another recorder that alows longer video capture , perhaps someone could tell you where to get it.
Hi.
Do a quick search and all your questions will be answered 😉
There are quite a few video products that will do what you want.
E-mail this guy and read this link http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=12413
Best
Will
eti, hipcam, hantro, there's loads, search the forums dude,
Found: tagtag.Com/sites/n/e/r/nerissa has answered all my prayers! Thnx for the advice everyone
Hi by eti camcorder u can mk video + audio as long as ur memory its free
