Sending photos to computer
6 replies · 1,715 views · Started 07 July 2003
I just got back from vacation and I took a bunch of pictures with my phone and I was wondering how do I send it to my computer? I have bluetooth and I have tried to send it via bluetooth but can't find the pic anywhere so can someone try to help me out on this?
Well, If you are using PC Suite, you can send the photo's anywhere you want. But lets assume you are not.
If you right click on your Bluetooth logo in your task bar, you can modify the Configuration. Part of that config is where the "FTP" directory is on your local machine. This is where any files that you recieve over Bluetooth will go.
So if you check in here you should be able to find where the photos went, and then change it to whatever you like.
just to add a few lines the the previous explanation:
go to your pictures folder, highlight a pic, click "options", choose "send".
this doesn't work with every bluetooth software. if you find yourself unable to send the pics to your computer due to some problem like "connection refused", go to the registry editor on your computer (Start->Execute, and then type "regedit"😉, and search for "acceptother". just change the value from 0 to 1 and it should do the trick.
Can't you just e-mail them from fone to PC? May need 2 e-mail addresses though
[quote="Anonymous"]just to add a few lines the the previous explanation:
this doesn't work with every bluetooth software. if you find yourself unable to send the pics to your computer due to some problem like "connection refused", go to the registry editor on your computer (Start->Execute, and then type "regedit"😉, and search for "acceptother". just change the value from 0 to 1 and it should do the trick.[/quote]
hi! where do i find this in xp? i did the reg edit and find "acceptother" but nothing is showing up.
everytime i try to send a file to pc it says "sending failed" on the nokia.
hope somebody could help.
thanks!
