I just recieved my 128mb card from the expansys and it says 128mb on the card but when i go to memory card info it says 30mb on it and i formatted it and everything but it still says 30mb does anyone know why it says this?
128mb Question
what firmware do u have?
press *#000# to find out
i bought my 128 card from expansys too when i formatted mine it says i have a 122mb card why is this
[quote="mattjuk"]i bought my 128 card from expansys too when i formatted mine it says i have a 122mb card why is this[/quote]
It's the difference between taking a megabyte as 1000 kb and 1024 kb - manufacturers usually quote as if it's 1000 kb as then you get a higher number on their product!
Sounds to me like yr 128 card is actually a 32! I'd send it back mate! 😊
also when memory is formated you will lose a certain amount of space for file tables etc.
yep,it si so,i habe 64mb MMC,but after formating there is only 61mb for use.
