I've got a registration code for AED which is installed on my 128MB duo card.
However, when I close the application from Handy Day, or the phone is switched off it loses it's registration details.
I have to keep entering them every time.
Anyone else having this problem? Or know why it's happening?
Problems Registering Advanced English Dictionary
That sounds really odd to me. Have you tried to uninstalling the Dictionary and then re-installing?
Yes, just tried uninstalling it and reinstalling it, then registering it again and it does the same!
I have to enter my registration details every time i want to use it (or keep it open in the background).
I presume you are talking about a legal copy of AED here? Contact the author of the application( http://www.jdictionary-mobile.com/contact.html ).
Yes, of course it is legal.
Just sometimes you get a quicker response here if it's also happened to someone else.
We all know how long some companies tech support takes!
Ok, it's just that the only time I've heard about a similar problem with an application was with someone using a "cracked" version..
Anyway, I use AED myself and have no such problems with it, so I'd suggest you give the tech support a chance..
I take back what I said about technical support.
I got a reply within an hour from them.
Apparently this happens in the first version they released for download and they are aware of it, I have to download it again.
Oh yeah that's right, I forgot they released an updated version right after their first release.. Hope the updated version solves your problem. It really is a great dictionary/"encyclopaedia". 😊
