what key combination do you enter to get the software versions etc?
and is there a page with a list of other hidden pages?
sure its here, cant find it in faqs. but you all seem to be posting your sw vers.
Jog dial up, *, Jog dial down, Jog dial down, *, Jog dial down, *
in the main application screen, you can also go to system information
not in applications, and the the jog* system doesnt seem to work (could be havent got the nak of the jog). this is a replacement from orange, and i'm pretty sure that the old one did have an option in aplications.
thanks anyway :robot:
Applications -> View -> System information
pretty sure all version have that
:angel:
thnks, it is indeed there, aplication/view/sys_inf
phone rf2
BT r5a
org r2b03
cda r3a01
My solution actually does work as well, but you have to be in flip closed mode off-course (and you need to do it rather quick...)
[quote="Delta737"]My solution actually does work as well, but you have to be in flip closed mode off-course (and you need to do it rather quick...)[/quote]
Yep it does but most dont understand what is meant with jogdial up and down 😉
:angel:
