Uninstalling.
3 replies · 1,396 views · Started 08 July 2003
f its java go to ur Menu > Apps and choose the application u want to uninstall by pressing "C" ..then u ll see a msg : Do u want to remove it? or somehting and press Yes ... if the file is symbian go again to ur Menu > Tools > Manager
[quote="SkylineG"]f its java go to ur Menu > Apps and choose the application u want to uninstall by pressing "C" ..then u ll see a msg : Do u want to remove it? or somehting and press Yes ... if the file is symbian go again to ur Menu > Tools > Manager[/quote]
Gotacha!!!
8)
the common way is as was posted before.ALSO when unistalling programm,ensure,that the programm is not in use.ALSO after unistalling some programms like OPERA..e.tc.On disk C: there will be some unuseable files like Opera.dat...also if you want delete them.
