Hey guys.....i know i should have serched the forum first :P ...but i did...there was a reg edit in there...i tired that....shut down the mrouter.....tried sending a file from my 7650 to my pc....i had to add the "acceptother" in the regedit....but no use 😞 .....then there was some program i should download "USBBTUSB-N"....from some site...there was a link.....but the link didnt work :agrue: .....so i am back where i was :roll: ...can some one help me step by step on this...i cant send nothing...even the msg saver wont work...just keep getting the msg "sending failed !"...or sometimes "maximum bluetooth connections alredy in use"..AHHHHHHHHH.....i have a MSI pc2pc bluetooth stick...running on a xp platform....help me eeeeeee.....need to save videos and msgs but nothing will go from my phone to my pc 😮 ....help needed A.S.A.P. !!!
cant send files to my pc via bluetooth
Do you think that this huge amount of red colour in your post will help?USBBTUSB-N would work,those are the drivers from bilinton.The registry fix doesn't work every time.If you can find an alternate url for the bilinton drivers download them.Try downloading the latest drivers from MSI,sending to PC will definitely work with them,i don't know about internet sharing though.
thanks ghost dog...but i went to the bilinton site to download the USBBTUSB-N but dont know where to find that.....would be a great help if you can give me the link to it....and i am downloading the lastest drivers for the msi....hope it works.....but if you can give me a link to the USBBTUSB-N driver...i would be thankful....and ...huh.....sorry for the red color mate....lets try this one :P
Sorry ishaqz,it seems that billionton have removed the drivers from thei website.I have them at home but i'm on a dial-up and i can't help you.Maybe some of the guys on broadband cand.Try the latest MSI drivers like i said,they just might work.
thanks again mate. But can you tell me how long is that driver file from bilington? you can give ti to me on msn. i am trying the msi new drivers. maybe they will work. but if they dont then last choice is the USBBTUSB-N driver. thanks anyways.
The file is 21MB's.It's just too much for me,like i said,i'm on a dial up.
