Can one buy the bottom connector of the 9210 anywhere? Either just the connector, or the connector with a cable attached. I have a system where it will be easier to connect the bottom connector to the instrument, instead of the dlr-2 cable.
Long, technical explanation for those that want it.
The system I'm working with also use 3V output levels. There is no need to convert this to a higher level with the dlr-2 cable and then convert it back to the lower level with my own components. All I need are some protection components. Also, the dlr-2 cable needs a power source, where I won't need that if i can get the connector.
Chris
I don't know what accessory prices are like in South Africa, but have you considered buying, say, a handsfree and using the connector from it? When looking for 9110 MBUS cables (or more correctly, looking for the bits I needed to make one...) I found that the connectors for the 9x10 are very, very, very hard to find. I do recall a site selling it online, but I can't for the life of me remember the address....
Good luck trying to find the connector!
[quote="AAY"]..., but have you considered buying, say, a handsfree and using the connector from it? [/quote]
This is the route that I'm planning to follow. I just thought to pop the question here as well to see if a better solution is available.
Chris
Here I can find the normal connector cable, but not a handset ... was planning to making earphones.
