NOW EXIST DATA CABLE FOR N3650 !!!!!
9 replies · 3,105 views · Started 09 July 2003
http://nokia3650.iwebs.cz/galery/index.php?galery=n3650&album=!!!_Nokia_3650_accessories_!!!&window_width=800&screen_widht=800&screen_height=600
Who mentioned USB Jimmy?
Thats a serial port for the PC end and the phone end looks spacific to the phone, certainly not USB?
This product is for sale on http://www.mobilefun.co.uk/product/1506.htm and when a member posted this on another thread you told them it was fake then too?
Now correct me if I am wrong, but isn't this just a version of the
cable that the Nokia Care Centres use to "flash" the phones.
IE. You remove the battery and Sim Card, plug the cable into the space the battery was in and away you go.
As far as I have read on the Web however, this is pretty useless to most users as PC Suite doesn't support the cable. It looks like the new version of Oxygen Manger may, but so far it dosen't.
So unless you have a copy of whatever software they use in the Nokia Care Centres, it probably is something most people will find useless.
The cable is real i have one. You have to take out the battery and sim card and stick them into the adapter as the connection points are under the sim card (six gold things) then plug the adapter on to the back of the phone. I have not yet found any software which works with the phone tho.
the data cable would most likly be faster at transfer also with the cable you can perform certain functions which you cannot do with bluetooth & IrDA
It seems there must exist some form of data cable for the 3650, i can confirm 2 but 1 of them was told be only used for flashing the 3650, the other one is the one in this topic
The one which i can see in the topic starters link, is this one:
But that one is only used for flashing the 3650, or am i wrong?
The other one is this one (from a topic of mine, see link above in this post):
I can not find the USB version in the gallery - link of ivomir, if somebody knows one, please post it...
