Connectivity
5 replies · 1,550 views · Started 09 July 2003
Hi guys,
Just got my 3650 and have a few Q's
1. What is the best way to connect the phone to PC: bluetooth, IrDa or cable?
2. I have a PDA (Siemens Loox 600) too, is there possibility to connect that with my phone? e.g. Pc suite to use on the PDA
I want to syncronise my phone with pda without using desktop if possible
ThanX!!
[quote="Anonymous"]Definitely, cable is the best way![/quote]No it isn't, as there are no connectors for that purpose (there are somewhat hidden connectors intended for flashing the phone, but not PC connectivity, and PC Suite for the 3650 only supports IrDA (infrared) or Bluetooth.
Bluetooth is faster and does not require line of sight like infrared.
true but it is possible to connect the phone using a cable but not for use with the nokia software (at present) there is other software which works (so i have been told) with cable connections.
IrDA is cheaper but bluetooth is faster and overall better
i advice you to use Bluetooth.loox 600 have BT,and you can download progs to your PDA(using N3650 as modem via BT),and then transfer them to 3650.
Yeah right, but what i really want to do is to connect my N3650 with the PDA and to sync calender and contacts. I manage to set up bluetooth connection but apparrently calender cannot be synced without going through my desktop using the pc suite. So actually I need a prog like pc suite for PDA. Anyone knows??
