What version of Smart Launcher do you use
7 replies · 2,666 views · Started 09 July 2003
I am interested so,cos i have installed Sm twice,after first installing the phone turned off,and didnt turn on,but i recovered it.AND today i installed SM twice,and after trying to start to play worms(via SM plane mode),the phone said contact the retailer 😉 ,(i was in shock),BUT i just turned it on,and all is ok now.SO LETS GO TO BUSINESS 😊 ,what ver.of SMART LAUNCHER do you use :roll:
From the sounds of it you are installing Smart Launcher onto the MMC card as this will give you the trouble you are having.
Smart Launcher is one of those apps that needs to be installed onto the phones internal memory inorder to run properly.
I have a 7650 and so do not have this trouble, but it has been causing some grief with 3650 users. Noramlly it means an MMC format outside the phone from what I've read.
Also make sure you have the newest version V1.02 as this had the bugs fixed.
Is this perhaps right and you were installing onto the MMC?
Ian
I have sLauncher installed onto MMC and never had a single problem with it
Ver1.02
Jimmy, perhaps another application is conflicting with it?
Best
Will.
[quote="willbrady"]I have sLauncher installed onto MMC and never had a single problem with it
Ver1.02
Best
Will.[/quote]
Same here.
SmartLauncher works from MMC with no problem. I haven't have any problems with it, although I only use it when I need lot's RAM. Skins just eats the memory and I don't like it!
Oh, I'm using 1.02.
I've learnt something new then, they must have fixed it to work from the MMC card in the newer version although I can't find out any documentation of it being done.
It may be another stab in the dark but, your not using a cracked version maybe? I've heard of problems with those apps and the 3650's, on this forum if I recall correctly.
Or dare we mention the WildSkinz's app, you haven't got this installed have you? Don't know if anyone's brave enough to user that app anymore
Ian
[quote="willbrady"]Jimmy, perhaps another application is conflicting with it?[/quote] No,..ALSO thanks for your replys..
