I was thinking of getting the IOGEAR bluetooth USB adapter but someone told me it didnt work with the 3650? And i heard about Belkins USB Bluetooth adapter but its kinda expensive. Which one do you guys have and reccomend getting?
Which Bluetooth Adapter Should I Purchase?
I just installed a Belkin USB BT adapter, after also having a 3com
Go for Belkin - installed easily with none of the problems normally reported with BT.
PCSuite & mRouter work perfectly - and no registry tweeks needed to send file from phone to PC.
Best 😊
Will
I got a Tecom. It's $25 at Ebay and they work well.
MSI here,works like a charm,cheap too.
I have a sitecom. It works pretty good 😊
I've seen a blue monkey BT USB adaptor for about �28 on expansys, according to theior website it's compatible with their 3650, i just wondered if anyone had used it or experienced any problems with it before buying one?? 8)
DLink BT 120, � 34, all OK! 😃
CIaoo!
I'm using an Epox BT-Dongle. No problems at all. Most adapters should work with the current WIDCOMM software.
im using a billionton bluetooth adapter.. works fine.. plug n play
All the way with TDK,
The new version of the drivers even comes with a "Help me attach to PC Suite" program.
