Anyone know what format I have to save a ring tone when using Ring Master so it can be transferred to 8910i ?
:roll: :roll: :roll:
wav?Doesn't work?
NO I tried that :cry: :-?
??????????? :roll: .rng with ring master?
I;ve just tried that and it comes up with the following message when tranferring it over via infrared to 8910i:
Unspecified error!
:roll: :roll: :-? :-? :x :x :x :x :x :x :x :cry:
Send it by SMS then?
Thats a bit of a problem as I don't get that option only the options to send it as a mail or infrared!
😞 😞 😞 😞 :cry: :cry:
EEEEEEEEEEEELP, please. :roll: :roll:
you can send it Via SMS by using the ringmaster app
try it cos i used it for the DCT-4 Nokia phones
cos when i tried with DCT-4 Nokia phones the 9210i telling me that the device does not understand the data format stuff
but it went smooth with all the DCT-3 Nokia phones
dunnoo why ...
Try the ringtone composer. I use it to send ringtones via sms. Its in nokia's original cd
[quote="J0J0"]Try the ringtone composer. I use it to send ringtones via sms. Its in nokia's original cd[/quote]
I have just looked in the Nokia recorder programme and there is no option to send as sms. :cry: :cry: :-? :roll:
I didnt say recorder, i said ring tone composer. Try to find it in forum.nokia.com or in the applications of the original cd. If there is not in cd like a seperate program, it's in the cd in the allnokia.sis file!
u said that u want to use the RingMaster App isn't it ??
so just use that app and the Send via sms option is there for u to use
