New 3650 site
31 replies · 6,158 views · Started 10 July 2003
Hi. I finally uploaded my 3650 site at http://36fifty.net. To be honest, the appearance of it isn't too impressive looking coz I just don't have enough spare time to play around too much, but anyway, there are a dozen or so movie downloads, 400+ ring tones, some wallpapers and op logos and some freeware apps and games. There's also a picture gallery so please get yr pictures in to me at [email protected]. Cheers!!
GREAT JOB,but isnt here breaking rules 😮 for posting such site with freeware games,IF THEY are really freeware(NOT cracked)its normal.
Cheers. I deliberately kept any illegitimate links/software off the site so that I may publish it here! 😊
"The Bush Presidential address'' is simply hillarious. A must see for everyone, though it may offend quite a few people.
Hi!
Your site is indeed very good. However, I wish to inform you that at least two of your files are corrupt (torch and nameswap). Kindly upload these files again. Is it necessary to install Screen Taker on the phone memory? It does not seem to work on MMC.
There seems to be another improvisation to get the display of names in the normal order. Enter First Name in place of Last Name and vice versa. But that may lead to problems with synchronisation with MS Outlook. Am I right? Or can we do some field editing there too?
Sanjeev Gupta
India
Cheers for your kind words chaps. I will try and add new stuff every week or 2 but like I said I don't have much spare time with my current job so we'll have to see. Thanks for the info about the corrupt files. They work fine on my phone so I'll try uploading them again. With screen taker, ignore what it says about the abc key. I think you use the pencil key. 😊
Hi! Please see the editing that I have done in my last post and give a suitable answer. By the way, what are these softwares for converting your mobile in to a TV Remote? Do these really work? I have tried to install, but the file was corrupted.
Pencil key works.
That is all name swap does. Just saves you the effort of re-typing your entries. Some people rate irremote, others don't. I got it working a little but found it more hassle than it was worth.
Hey!
Please upload the name swap file at the ealiest and inform me at [email protected] The sis file available right now is only 2 KB after unzipping. It is showing it as corrupted on other phones as well.
Wouldn't let me send it. Try downloading it from the aas site or my-symbian
Buddy... i seen ur site....... want to make some suggestions....
ringtone section, u should display the list of rightones alongwith download link instead of one huge zip file (2.69MB).....anybody want a particular
rigtone... he should able to download it..... this will save time...... most of us having almost all ringtones....same thing about wallpaper.... display it
with picture instead of zip file......otherwise ur site looks like text based website.........
Thanks for the input. Constructive criticism is always welcome. 😊 I appreciate what you are saying, but I have neither the time nor discipline to list over 400 ring tones. Similarly, with the wallpaper there is a time issue as a lot of them would need re-sizing before putting them on the page. However, I may do as you suggest for any future updates as there won't be any to do en masse. 😊
[quote="jimmy-floyd"]GREAT JOB,but isnt here breaking rules 😮 for posting such site with freeware games,IF THEY are really freeware(NOT cracked)its normal.[/quote]
I usually dont flame but everytime I see you post you say something negative, irrelavant or just plain stupid. IT SAYS EVERYTHING IS FREEWARE. READ AND THEN POST. Now I feel much better... We can finish this on pm kid
[quote="forlan"]in sites like these, content is what matters, not the look of the site..[/quote] But there are NOT so many good,and must have app.and games on this site.
[quote="Ptm"]Thanks for the input. Constructive criticism is always welcome. 😊 I appreciate what you are saying, but I have neither the time nor discipline to list over 400 ring tones. Similarly, with the wallpaper there is a time issue as a lot of them would need re-sizing before putting them on the page. However, I may do as you suggest for any future updates as there won't be any to do en masse. 😊[/quote]
dont' put all ringtones...... make a selective collection....
if u want to put all... then make it in category like A-C, D-F, ....
like that....
I know.... but if u have well designed site...... nothing wrong with it....
it reflects your image, creativity.........
I think all 400 tones in one file is much better!
Download the lot - then browse them offline in your own leasuire.. Surley thats better - and cheaper on the phone bill for us dialup users.
Great job 😊
For anyone who is interested, I've had a couple of days off work and spent a fair bit of time working on the site.
Both apologies and thanks must go to this forum, coz most of the new stuff has been robbed from various threads here!! 😊
Thanks also to Will for sending me a bunch of trailers.
I've redesigned it slightly and added a couple of new bits and pieces.
So if you wanna go see:
http://36fifty.net
Cheers,
Ptm
My web site was on telly!! In the USA!!
On Leo Laporte's 'The Screen Savers' on Tech TV on 4th September! 8)
Then over 2,000 people visited in 1 day and I'm now worried my 20 gig bandwidth won't be enough!! :-?
