Where can i download video clips via wap, using GPRS? All i can find is porn, which is fine by me, but kinda awkward if relatives/girlfriend asks to see the wonders of mobile video!!
.3Gp rm or oplayer downloads?
Not just porn mate, plus these ones are free 😉
For RealOne
http://194.164.20.8/terminator3.zip
http://194.164.20.8/thehulk.zip
http://194.164.20.8/matrixreloaded.zip
http://194.164.20.8/animatrix.zip
http://194.164.20.8/toystory2.zip
http://194.164.20.8/toystory2b.zip
http://194.164.20.8/chaliesangels.zip
http://194.164.20.8/chaliesangels2.zip
http://194.164.20.8/dusktilldawn.zip
http://194.164.20.8/entrapment.zip
http://194.164.20.8/et.zip
http://194.164.20.8/fightclub.zip
http://194.164.20.8/frequency.zip
http://194.164.20.8/interview-with-the-vampire.zip
http://194.164.20.8/jurassic-park.zip
http://194.164.20.8/men-in-black.zip
http://194.164.20.8/minorityreport.zip
http://194.164.20.8/missionimpossible2.zip
http://194.164.20.8/nightmareelmstreet.zip
http://194.164.20.8/scarymovie.zip
http://194.164.20.8/sixthsense.zip
http://194.164.20.8/sleepy_hollow.zip
http://194.164.20.8/terminator.zip
http://194.164.20.8/terminator2.zip
http://194.164.20.8/thematrix.zip
http://194.164.20.8/toy-story.zip
http://194.164.20.8/matrixfinaltrailer.zip
Best
Will
Keep getting: "services: operation cancelled!" why?
Where are you seeing that and what are you trying to do ?
Downloading over wap Will. It won't work. To the guy who asked the question, does it need to be wap? If u can go via a PC, my new site at 36fifty.net has a few .rm's. Plus the links page will give u loads more. 😊
Over WAP ?
Download them to your PC bro and transfer them.
They are quite big files and they are zipped
They are not meant to be downloded over WAP.
Thanx guys. I'm gonna invest in an I.R link to my PC.
I bought a card reader for under a tenner from PC World. Works a treat. Very quick and very easy. 😊
Hmmm... Tell me more about this card reader...
So what make/model of reader did you get?
It was the cheapest multimedia card reader in PC World. By Dazzle. Price was marked up as �12.99 but rang on the till at �9.99. 😃
Just plug it into a spare USB port. Then whip the card out of your phone and stick it in the slot. It then acts just like any other hard/floppy drive on your PC, so you can easily move stuff around. When you have finished, be sure to right click on the drive name and select eject, otherwise it may not finish file transfer correctly.
If you are installing apps or games, be sure to download a file manager over WAP as you will need it to see the installation files on the card.
It isn't suitable for ALL applications, as some programs require an active connection between phone and PC, but just for moving files around it's poifik.
Hope that helps.
Ptm
