Best Camera Application
14 replies · 3,373 views · Started 11 July 2003
Hi, i've searched the forum and havent been able to find a specific answer.
So i'll ask here. I was just wondering what the best camera app is for the 3650. I currently use the 'Camera' on the phone that came with it, and i am pleased with it. But i've read other reviews that allow you to do different things i.e. zooming to 2000% etc.
Which is the BEST camera app. Quality of the picture is the MOST important to me, so are there any apps better than the one that came with the 3650?
Thanks for the help.
Arni
excellent link! 😃 but are there any specifications that say one is better than the other for a fact?
Also, which is best in terms of features?
I think best software is CameraFX, if you look for features. But if you are looking for quality then i'd say JanSoft Camera or Photographer.
Btw. I got CameraFX, Photographer and JanSoft Camera installed, so, it not big deal for me, hehe.
i am using Photographer 2.02 too, but this app is very usage RAM memory, shita app. still i have error low memory and must restarting in safe mode grrrrrrrrrrrrrrrrrrrrrr
[quote="ivomir"]default camera has very very bad image quality ![/quote] NOT AT ALL,i am using CAMERA app.,cos you can capture an image very quick.
Original software is handy when you wanna take pictures fast.
I got Photographer 2.02 too and I got no memory problems.
check the snaps in BEST PHOTO CONTEST taken by me and then speak
........ no doubt janesoft camera gives sharper pic than the default one....but takes lot of memory (10 times)..... in Photograper if u can zoom more, picture quality deterioting....
I installed CameraFX by PC Suite but I can't find the programe on my phone.. did I install it wrong, what is the correct way to install it?
All my pix are taken with the default camera app - take a look in the picture contest thread they look perfectly fine 😊
I've tried all the others but always go back to the default app because it's so easy to use sitting there on the softkey.
Plus I can't honestly see that much difference in image quality.
Plus with the default app you always know whatever pic you take will be of a suitable size for e-mail / mms or whatever you want to do with it.
With the others I was forever having to think before taking a pic "what am I going to do with this pic" e-mail - mms - send to PC, then change the settings to get the correct file size.. you then lose the spontanuity and fun from having a camera on your phone!
Just my opinion 😊
i installed cameraFX again and this time it works, but I can't TAKE any pictures because it says: pictures can only be taken with the full version of CameraFX.. where can I get the full version and what kind of version do I have no than?!
you must have the free trial version. goto www.wildpalm.co.uk and you can buy the full product 😊
Will.
