Some questions.
5 replies · 1,464 views · Started 12 July 2003
Hi all, I just got my 9210 back from my dad, and the phone's recorder seems to be screwed up. It skips when I try to record stuff, is there anything I can do to fix this?
And also, what's the current firmware for it? I'm thinking of upgrading the firmware together with my 7650.
I have the exact same problem, my communicator skips when I record stuff, it doesnt happen often, but still it happens.... It didnt bother me before since I dont use the recorder often.... but since you brought it up, I wonder whats wrong.....hhmmm :roll:
The last up-grade is 4.13 (9210 not 9210i)
Change the recording quality to the maximum,it eats more space but the quality is much better and it shouldn't skip.
[quote="TheSpecialBoy"]When I have problems with apps, I use to reinstall them...
Never heard of this issue before 😞[/quote]
same hir. Wat ver u using?
