My wife uses a 7560, myself a 9210 communicator.
We have transfer contacts properly between our phones using Infra red and using Vcards - even the pictures are copied.
It turns out that the contact databases from a 7560 can be opened in a 9210 when saved on the moment card - the format is almost ok, however there is some corruption.
It appears that Nokia changes the contact database formats between Series 80 and Series 60 - why!!!!
However you can only do this one at a time and cannot synchronise them - oh try PC suite you might think - well.
The 9210i PC suite does not support 7560 and the same is true is the other direction - PC Suite for 7560 has import for most Nokia's including
the 9110i communicator (which I used to have) but very strangely not
the 9210!
Another odd thing is that the 9210 cannot handle messages from the 7560's message store.
If somebody is producing a complete replacement for the 7560 PC suite
please let us know.
A key problem is 'selective restore' - the 7560 PC does not have this
and the 9210 PC does - why again!
