What card reader type?
7 replies · 2,836 views · Started 12 July 2003
I have been informed that the cheapest/easiest way of sending files from PC to 3650 is a card reader, but what kind. All i know is that i have a 16mb MMC memory card in my fone. Can someone pls shed some light on this...eg. What format card reader i need, as there are many different types.
is it possible for me to transfer files over ic card reader (4 drives: sd,ms,cf,sm)? i don't know if it is the right stuff for it
Not sure I understand the question. If you mean yr PC has some card slots then yes the SD slot will read yr MMC.
Originally posted by B3AN
you just need a MMC (MultiMedia Card) reader alot of the 5-1 or 6-1 readers have support for MMC. you then just stick the MMC into the reader.
examples:
http://www.ebuyer.com/customer/products/index.html?action=c2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=48182
http://www.picstop.co.uk/pages/products/cardreaders/sdmmimagemate.htm
Hope this helps
I got this EuroCom USB V2.0 External 7 in 1 Card Reader/Writer
from http://www.dealsonic.com/euusbv2ex7in.html
But when I try to stick my 16 mb(came with the phone), Nothing happen, I can't read my MMC
I'm using Win XP home edition,
What software do I need ?? I try to read with WIn Explore
I install PC suite but I can't do anything with it cuz I don't have anything to connect to the phone. SO How can I use Nokia PC suite to install software in to my phone ???
THanks
