Outlook Sync of annual events
2 replies · 1,714 views · Started 13 July 2003
Annual events set within contacts or otherwise dont show up on the P800.
Has anyone noticed this and found a solution?
I have the same Problem and did not find a solution till now.
Generally repetitive Dates don't show up in the P800.
I am very disappointed of how the sync software works....
Hope there will be a solution soon!!!!
Yep, it's a well known problem (along with synching of Outlook catagories\groups and various other things). SE have just never found a way to get it working. Same thing with Lotus Organiser too.
You can use Handy Dates to achieve a smiliar result on your P800, but you won't be able to edit them as recurring annual events within Outlook once you synch.
Basically, you use your P800 to create, edit and control your annual events with Handy Dates. This then creates appointments\reminders within the calendar application and these get synched to Outlook\Lotus\whatever. But you do HAVE to use the P800 to make changes. As far as Outlook is concerned, each annual event is actually just a load of single appointments that happen to fall on the same day each year. Making a change to one appointment doesn't affect the others and screws things up.
It isn't a perfect solution and takes a little getting used to, but it's the best I've found so far.
