Can't delete a Stuck msg in OUTBOX Nokia 7650 !
5 replies · 4,317 views · Started 13 July 2003
Hi everyone!
I hope this would help, puttin forth my problem infront'o everyone out here..Anyways.. I have a msg stuck in my OUTBOX which I cant delete or erase.. My Nokia 7650 version is v3.12 , I have browsed the folders in my mobile via File Explorer but cant find any SMS Folders.. Please let me know if theres any software that can help me erasing it or some type of "reset" is required for this..??
Please reply anyone who can help OR simply email me :
" [email protected] "
Thanx!
Love..
Saira 😉
same thing happens to me.. i just had a soft reset *7370# its gone..but all of ur apps,images,messages,contacts,etc.. will disappear too. :cry:
Hi again!
Thanx "b.fly" for your help but b4 I make the reset I would wanna know that If I make the backup of my mobile contacts etc. via Nokia Pc Suite, will my SMS messages in " My Folders " be also preserved ??? or is ther any other way I can save those SMS messages in my PC for later transfering back to my cell..??
Thanx again neways!
LOVE
Saira! 😉
I'm not sure about backing up message with PC suite(Its been a long time since i've done a full backup),but i think it should work.
You can save your messages to your PC using an app called Message Saver.The downside is that it saves them in plain text format.
Small advice: Update your firmware ASAP,v 3.12 is very buggy and if you are not careful and excidently fill up your phone's memory(IE:Takin pictures)it might end up dead and you will loose your data or even worse.
Hi again!
ammmm... well I think you are right.. I should better go for an upgrade to my v3.12 firmware...! Except messages everything can be backed by PC suite I guess.. so b4 making a RESET finally, if anybody knows some ware that can get me to save the "My Folder" SMS msgs to PC and then after reset, can help me restore them back, coz I have over 80 msgs and I obviously dont wanna lose'em :roll: ...
Also If i dont do a reset and go for a "firmware upgrade" straightaway, that would clear up the whloe data as well neways isn't it ?? For that i'd be needing a backup as well am I right ?
Reply if anybody knows more...
Thanx
LOVE...
Saira 😉
