I don't know if this query has been posted. I am trying to SMS to a specific group(which i have grouped), for Nokia 7650 i know all i have to do is just select the group, so how about P800 ? anyone knows ? or do i need 3rd party application ?
Mass SMS to a certain group...( a solution..perhaps... )
Pretty keen on this to.
Maybe the next version of SMS Manager will have it?
Actually i kinda figured a temporary solution to that. First i go into a SMS, and i select the people i usually will SMS in a group. Then i do a COPY AND PASTE into the JOTTER. And save it. So the next time i want to SMS to the same group, i will just open JOTTER then SELECT ALL,COPY and PASTE it into the TO: inside the SMS. I am using this method which is easier, rather than goin through the entire contact list and TICKING those i want all over again. Hope this helps some of you.
Outstanding!! Tips of the week by Acidbyte!!!
Rejoice!!! 😃
8) Coolness!!!! Now we can have a folder im Jotter for each group that you have eg: friends, family, co-workers!!! Yaaaah!!!! Thanks for the TIp!!!! 8)
i don't know if there is a limitation on the number of entries on the "TO:" in the SMS when we do the mass SMS. But so far this is only what i can come out with.
