belkin t8 001 bluetooth problems! help!
3 replies · 1,847 views · Started 13 July 2003
i just bought the belkin t8_001 adapter and it recongnized my phone but when i go to connect through serial port it then says "mobile device closed connection" does anyone know how to fix this?
Have you paired and authorised the devices..
Go to their site a grab yourself the latest drivers..
www.belkin.co.uk
I have a belkin and the new drivers work fine.
But I did need the OLD version of mrouterserial.dll from the original PCSuite before mRouter would list the BT comm ports.
Do a search - there is loads of info o this.
Will
thanks...i am new at this symbian stuff i only have had this phone for 2 days...what should i search for...where is there other info on this topic..thanks -ryan
These should get you started.
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=3075
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=14072
BUT if you download the latest drivers from here:
http://web.belkin.com/support/download/download.asp?download=F8T001&lang=1&mode=
Most of the above problems have now been resolved.
Best
Will
