does anybody know how i can use my 3650 as a webcam?
USE MY 3650 AS A WEBCAM
Did you search the forum?There are several ways to do it.Search the forum before repeating questions.
If u search the forum, you will find another fool who should've searched the forum. And if you search it further you will find your answers.
still same questions
arrrgh
i have enought this ppl
[quote="Arni"]If u search the forum, you will find another fool who should've searched the forum. And if you search it further you will find your answers.[/quote]
That would not happen if people would just comply with forum rules and do a quick search before repeating questions.Try searching the 3650 forum for "webcam" using the Search feature,its quite easy,you'll be suprised with the results.
