Can I use 7650 files/application/games in 3650 phone?
17 replies · 3,150 views · Started 13 July 2003
as per my knowledge...... yes......without any trouble.....
if u find 7650 games in multiple files........ zip them all in one.....
then send it to cell.......
Jimmy, please don't give false info..
Not ALL games except worms, how do you know that, have you installed EVERY game?
The best advice is - try them on your MMC, some games/apps will be fine and others will not work as they are hard coded to look at the c:\
So if you come across any of these then just re-install to you phones memory.
Thou to be honest MOST games & apps now have been updated and DO RUN FROM mmc without problem.
As a developer - tester, I have installed LOADS of applications on my 3650 over time and have only got 2 on my phone memory at present, and I'm sure if I could be bothered to go and get the latest versions they would now work on MMC
Best 😊
Will
I said so,cos the structure of N7650 and N3650 OS systems is the same.The only diffrence is in RAM,.N7650 has got more RAM.but its not a problem,user of 3650 can close unusable progs(to free up some ram),and all will be ok.and in my previos post i minded MAIN memory.
Did anyone understand that?
I here what you say mate - but your making no sense when used in the context of the question - your answer - my answer - your reply????
Man they must have some strange drugs where you come from 😮
I said in my previos post that games designed for 7650 worked perfectly on 3650 in Main memory(not MMC),you are saying that they work on MMC,i agree with you.
LOL!
Must be your Russian to English translation, I've read your post over and over and it still reads like you are saying that you MUST put games onto the phones main memory and NOT the MMC for them to run!!!!
LOL!!
Then in your next post you are contradicting yourself by saying you agree with me 😊
Maybe that's the problem all long, not that your talking rubbish, just that what you are saying is misunderstood because of your Russian 😊
Oh well 😊
I applogise if I got the wrong end of the stick and had a moan at you for no reason.
[quote="jimmy-floyd"]I said so,cos the structure of N7650 and N3650 OS systems is the same.The only diffrence is in RAM,.N7650 has got more RAM.but its not a problem,user of 3650 can close unusable progs(to free up some ram),and all will be ok.and in my previos post i minded MAIN memory.[/quote]
u mean that 7650 got more memory then 3650?? i tot that 3650 got more( that is with added mmc )
[quote="eone"][quote="jimmy-floyd"]I said so,cos the structure of N7650 and N3650 OS systems is the same.The only diffrence is in RAM,.N7650 has got more RAM.but its not a problem,user of 3650 can close unusable progs(to free up some ram),and all will be ok.and in my previos post i minded MAIN memory.[/quote]
u mean that 7650 got more memory then 3650?? i tot that 3650 got more( that is with added mmc )[/quote] 7650 has got MORE RAM memory.
but i read from nokia.com site.
they say 7650 has 3.6 meg...and 3650 has almost 4 meg
how come u say 7650 has more than 3650?
i read it here http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=14381 ,on first page find post By IVOMIR(he said:This is not possible.
Nokia 7650 have 4MB of ram
Nokia 3650 have 3.2 MB of ram
[quote="James316"]but i read from nokia.com site.
how come u say 7650 has more than 3650?[/quote]
no...... i think 3650 has 3.6 meg where 7650 has 4 meg basic phone memory........ in addition, 3650 comes with MMC.....
i will explain:N3650 has two types of memory:MMC card,and built in memory(or main memory,disk C😊,AND it has RAM memory.
Just jumped in here and I think your all getting a little confused so I'll have a go to 😊 probably won't help but what the hell this is what I've come to understand from reading and listening.
From what I have read the 7650 has more RAM compared to the 3650. RAM being Randomly Accessable Memory just like in a normal desktop PC. This is used to actually run the programs from to make them run smoother and faster, hence the 7650 is capable of running more than one app at a time without getting to bogged down with the actual running.
On the other end of the scale, the 3650 has more memory space to store more apps, pictures, files to in the form of the MMC card.
Both phones are indentical in their make up, except for some slight alterations in the included software, namely Real Player and marginally better camera software out the box.
Jimmy was right in his last post in that there are 3 memory types in the 3650, Internal (4Mb), MMC (unlimited, lucky buggers 😞 and RAM.
Atleast I think this is right anyway. Ian
[quote="coolice"]Hi,
[/quote] yes you are almost right.
